RE: EI Timing for conversion engine
The total timing on all our conversion engines should be 28 degrees
The CH and RCEXL ignitions when moving the magnet past the sensor at the bench should both be 28 degrees before top dead center
A stock Homelite 30 with open muffler and a 11 mm carb should turn a 18 X 8 prop at 7400 rpm
