Chemie: That is the glue that I used. I lined all up marked the fuselage with a sharpie, then applied the glue and used masking tape to hold in position. I believe that the little bit of "spring" in the cowl lifted the masking tape around the edges.
I have refitted with servo screws abd have a good fit all around except for the front left where there was a gap of around 1/16" between the cowl and the fuselage. I placed a cloth over the cowl and used a heat gun on the high spot - carefully. It worked, shrunk nice and snug. I could now use the canopy glue and get an excellent fit
Now to add some covering around the cowl edges.
Rick : I haven't seen the plastic polish before but will have a look as I have a headlight lens that could benefit anyway.
I have 2K MS primer for the plastic cowl and etch primer for the aluminium legs. Light coats, Sometimes it is easy to get carried away in the moment....
. Thanks for the reminder.
