RCU Forums - View Single Post - the case of the missing prop blade
Old 04-28-2010 | 08:23 PM
ozzie-crawl
Default RE: the case of the missing prop blade
i am assuming there plastic props ?
i tried some along time ago just as test props, using them to test what works best then once i determined what was the best size replace with a metal prop.
unfortunately the plastic props are not always very good everyone i tried broke at around 2/3 throttle.some had the centre bore off line others just to weak
i would suggest a metal prop or carbon props
