this is probably the best place to get props
http://www.offshoreelectrics.com/categories.php?cat=16
have a look on some forums for the boat you have and see what props guys are changing to, the carbon ones are cheap and dont need balancing so you can try a few different ones.
some smaller shafts need a adapter, usually a small piece of brass tube does the trick.
