RCU Forums - View Single Post - sunuoo 6 ch receiver
Old 04-29-2010 | 11:04 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: sunuoo 6 ch receiver
ORIGINAL: avgrech
so does it need some special transmitter or can i transmit with any 34.190 mhz transmitter ????
because i have just put in everything and nothing is working with my transmitter and i did hook up the power correctly because when i connect the battery the servos move a little .
Yes - it does need some special transmitter.
No - you cannot transmit with any 34.190mhz transmitter.
There are many pitfalls and no one here can help unless you are forthcoming with information like exactly what Transmitter, make AND model you are attempting to use. Same goes for picking out another Tx.
This is the reason its very bad form to start trying to mix and match a system together when you are new and most who do end up paying twice as much as if the had bought a complete starter system from the beginnings.
So what do you want to do? care to post all the needed info on the tx or a workable link so someone can try to trouble shoot?
