RCU Forums - View Single Post - ESC help!
Thread: ESC help!
Old 04-29-2010 | 11:22 AM
ryan_t888's Avatar
ryan_t888
Default RE: ESC help!
In this thread I don't see the physical size of the motor. A 28mm x 35mm may only draw 30A where a 36mm x 65mm may draw 80A and a 39mm x 100mm may draw 180A. All 2700kv on 4s
I’d imagine the OP would be fine with a 120A ESC as it’s pretty standard but lets not assume. Especially since a very hot setup will be used. – 4s on a 2700kv motor.
What hull is this setup for? What length is the hull? What prop is being used?
Ryan
