ESC help!
Hi, I would like help on deciding what ESC to get. I'm not sure what amp ESC my boat requires so here are the specs:
2726KV motor
Dual 4S 14.8v 4500mAh 20C LiPos
I also have another boat with a 1620KV motor and would ideally like a ESC which can work with both motors if thats possible?
I believe my current ESC is 70a for the 2726KV motor and I had to attach a 5A UBEC to it myself.
Thanks.
2726KV motor
Thanks.
Is this okay? It says it has a built in BEC so I'm guessing I wouldn't need to attach a UBEC to it?
http://www.hobbywing.com/english/Art...?ArticleID=451
OH
Man I don't know what the price on that ESC is but that looks like a re-branded turnigy to me. the spec sheet looks identical. HK had htem for less than 60 bones.
In this thread I don't see the physical size of the motor. A 28mm x 35mm may only draw 30A where a 36mm x 65mm may draw 80A and a 39mm x 100mm may draw 180A. All 2700kv on 4s
I’d imagine the OP would be fine with a 120A ESC as it’s pretty standard but lets not assume. Especially since a very hot setup will be used. – 4s on a 2700kv motor.
What hull is this setup for? What length is the hull? What prop is being used?
Ryan
Ryan
ORIGINAL: ryan_t888
Ryan
Ryan
The length of my motor is around 72mm, I am running 4S Lipos parallel. My hull length is 32" deep vee mono. The prop being used is the one supplied with the boat in ARTR condition which is a brass unbalanced and unsharepend prop which has a diameter of roughly 42mm, I have tried sharpening it myself.
i have a 25" mono with 35mm brass prop, 120a turnigy esc, 380XL motor and i use 3s in parallel
i use 2s in series in both my cats through a 540 8XL spinning 38mm CFprops
ORIGINAL: StarscreamF22
The length of my motor is around 72mm, I am running 4S Lipos parallel. My hull length is 32'' deep vee mono. The prop being used is the one supplied with the boat in ARTR condition which is a brass unbalanced and unsharepend prop which has a diameter of roughly 42mm, I have tried sharpening it myself.
ORIGINAL: ryan_t888
Ryan
Ryan
I personally would run a different motor with a larger prop.
Ryan
