RCU Forums - View Single Post - ESC help!
Thread: ESC help!
Old 04-29-2010 | 12:31 PM
StarscreamF22's Avatar
StarscreamF22
Default RE: ESC help!
ORIGINAL: ryan_t888
In this thread I don't see the physical size of the motor. A 28mm x 35mm may only draw 30A where a 36mm x 65mm may draw 80A and a 39mm x 100mm may draw 180A. All 2700kv on 4s
I’d imagine the OP would be fine with a 120A ESC as it’s pretty standard but lets not assume. Especially since a very hot setup will be used. – 4s on a 2700kv motor.
What hull is this setup for? What length is the hull? What prop is being used?
Ryan
The length of my motor is around 72mm, I am running 4S Lipos parallel. My hull length is 32" deep vee mono. The prop being used is the one supplied with the boat in ARTR condition which is a brass unbalanced and unsharepend prop which has a diameter of roughly 42mm, I have tried sharpening it myself.
