RCU Forums - View Single Post - advice on starting old engine
Old 04-29-2010 | 05:13 PM
flyinrog
Default RE: advice on starting old engine
If you have some fuel,,that will free most engines up fine....pull the plug as said...pour some in the plug hole, fill the carb, make sure it turns freely too, remove the needle valve and put it in there too.....spin it over, if there is resistance than work it back and forth until it spins over,,dont look down the hole or you'll get an eye full......Rog
