RCU Forums - View Single Post - advice on starting old engine
Old 04-29-2010 | 10:13 PM
Gizmo-RCU
My Feedback: (27)
Default RE: advice on starting old engine
A little heat from a heat gun can sometimes help the oil/fuel, etc. cut thru the gunk. Slowley work the prop back and fourth gradually dislodging the varnish from the piston and crank. You will may have to remove the back plate to soak from inside. I would do this as a matter of course as most of the stuff/gunk/dirt,etc. will be accessable from the back.
