RCU Forums - View Single Post - Carb location?
Old 04-30-2010 | 04:34 PM
Tired Old Man
Default RE: Carb location?
A simple tube with a "L" bend will often suffice when attached to the diaphragm cover. 3w found that routing a tube from the diaphragm to the carb inlet was the most consistent method of correction. tests elsewhere confirmed the validity of that design.
Front mounted carbs are not the best way of doing things with a gas engine.
