RE: Carb location?
And I found turning the 3W venturi so air is forced in got 200 more rpm....On my test stand...Twin cylinder pusher drone engines have the carbs facing forward..there's a tube in the venturi at a 45 degree angle that leads to the cover over the metering diaphragm..No other holes in the cover...Works very well in that application....
