RCU Forums - View Single Post - Carb location?
Old 05-01-2010 | 07:16 AM
pe reivers
Default RE: Carb location?
I have tried all kind of things, including the tube to the carb mouth. Latter can be made to work, but is quite engine specific. Location and angle of tube ending in the carb mouth are critical, because airflow affects regulating pressure (sometimes to advantage).
I still found the static tube approach the best overall solution, with the static tube located outside the plane fuselage in straight airflow regions.
