RE: Extreme 88
There are 2 stab retainers. The foremost is directly below the new anti rotation pin position so holes are required for both. Ive done the ar pin hole but i want the 2 retainers as per original config. Without removing the original position blind nut you cant fit a new one for the new position hence need to remove so i can get the new one in. (this isnt an incidence problem this is that the stab i have doesnt fit the fuse see original post).
