RE: is this right
if you want to lighten up and get more punch get 2 6s 5000mah lipo packs and run them in parrallel, they are at 22.2v each, and you'll have 10ah total current draw ability. probably half the weight, and will work with your current esc setup. just make sure to get a little low voltage alarm as im sure your esc doesn't have a cutoff.
