RCU Forums - View Single Post - Idle Problem
Thread: Idle Problem
Old 05-02-2010 | 12:34 PM
Kelly W
Default RE: Idle Problem
Having the ECU run while the restriction went higher (from the plug) may have re calibrated the fuel curve and confused the ECU a bit. If I understand how Garpar's ECU's work, I think the ECU should correct the problem on its own and re adapt with more run time. Try starting it and let it run through a tank or so, cycling the throttle up and down a few time occasionally, then check the idle consistency again.
Kelly
