Idle Problem
CA
Hello all.
How are you guys? I recently up dated my ECU to Xicoy 605 ECU. I test run the engine a couple of times before, and it worked flawlessly.
However, today I was starting it up for a brake test, and I had forgotten to remove the fuel vent plug. The pump collapsed the UAT, and
engine quit. After I removed the fuel vent plug, the engine start fine with a couple of spurts of blue fire from the exhaust cone. The terminal
indicated that it achieved running status, but soon after reaching the idle RPM, it begins to surges up and down up and down between 34000 to 35500
for about 15 seconds then it shuts down. I reset the power, ECU, nothing seems to work. Please help if you gents would happen to know the culprit.
Thank you so much.
Thank you so much.
CA
Hi Ruiz.
The ECU stated low RPM when it shuts down. The RPM during the starting process was normal, smooth. Only when the terminal
display "running" message, that's when it surges.
My Feedback: (29)
The low rpm message could mean a fuel delivery problem(ECU knows it's pumping fuel, but RPM are decaying past the shutdown threshold), most surely restriction, as said, the UAT collapsing may have forced foreign matter past the membrane, check your fuel filter, open UAT and remove membrane and check and clean...
CA
Hi.
Thank you so much for your assistance. I will try to test it again tomorrow and bypass the fuel system altogether to see
if its the pump, or the tanks. I am suspecting its the tanks issues too.
Thank you again.
Thank you again.
Having the ECU run while the restriction went higher (from the plug) may have re calibrated the fuel curve and confused the ECU a bit. If I understand how Garpar's ECU's work, I think the ECU should correct the problem on its own and re adapt with more run time. Try starting it and let it run through a tank or so, cycling the throttle up and down a few time occasionally, then check the idle consistency again.
Kelly
Kelly
CA
Hello all.
I bypassed the tanks altogether today, and it ran perfectly, so I guess its time to troubleshoots the tanks then. Will post as to why. Thanks again for
all of the help guys.
