RCU Forums - View Single Post - Airsoft and IR ?
Old 05-02-2010 | 02:41 PM
1sgt
Default RE: Airsoft and IR ?
ORIGINAL: pattonrocked45
I am all confused. wouldnt a rx18 support ir? now if a dbc unit is the common ir module how many volts does it take to trigger? i'm just not seeing why the 2 systems could not work together? i have no clue how a dbc works, hell not even sure how ir works on a rx18. but wouldnt it the ir system have to turn on and turn off? if both ir systems work with aisatam and hl recoils i cant see a problem with airsoft too.
My thoughts exactly. I mean like I said, you may have to unplug one system to run the other, or at least have a switch interface between the two systems. In basic thought, it should work, in reality I don't know and don't have the expertise to figure it out. That's why I'm hoping some of the RC wizards will take an interest.
Jim
