RCU Forums - View Single Post - Airsoft and IR ?
Old 05-02-2010 | 06:10 PM
Panther G
Default RE: Airsoft and IR ?
Well sarge if you want to go too Danville you should really consider a system that makes it Tamiya compatible obviously. Although I have very good relations with bill at RCC the DBC system can be used with a good hobby grade radio and reciever which would really be a big plus. Get away from the cheap AM frequ systems (HL) and go with the DBCRC2. You just need to work out a way to get a gun flash incorperated into the works. One way to do this is get an Asiatam FO turret for the IR system. It's a good option . Costs as much as another tank so Jeff is correct too, Just buy another tank to set up FO IR. Then you can have the best of both worlds and gives you an excuse too get the CO at the house too allow you to get another tank LOL.
