HPD-O7RH Reciever
Hi I have a quick question concerning the Hitec HPD-O7RH reciever, I have been using the Hitec Eclipse 7 radio with the spectrum module in 72 MHZ and decided to try out a PCM for a change. The reciever works great with no problems but one, I can't seem to get it to take the failsafe. I followed the addendum sheet to the letter several times and still nothing works right. I moved the servos to where I want in case of a issue,push both the menu buttons at onceand hear the double beep. shut the transmitter off then back once and twice to be sure. With the transmitter on moved the controls surfaces off center and then cut the transmitter power and I get nothing. However I do get something that is rather strange upon turning the transmitter back on, the surfaces will not recenter themselfs unless I move the sticks. With the failsafe off this does not happen the surfaces go back to the centered places when power is restored to the transmitter.
I have a couple of other radios with failsafe recievers and none of them act like this, they go to where you had the servos set to go in case of a power glitch or outage, Or in case of a outage the servos go to the preset condition.
Do all the servos need to be Hitec in order for this to operate or does it matter?
Any help would be greatly appreciated.
Richard.
