RCU Forums - View Single Post - FX Needle valve
Old 05-03-2010 | 11:47 PM
TwistedProp
Default RE: FX Needle valve
ORIGINAL: GSJames
This is what I do on both my Open B combat planes and my Q-25 pylon racers. I use this aftermarket OS needlevalve:
http://www3.towerhobbies.com/cgi-bin...&I=LXCR48&P=ML
And then I attach it to the airplane using a large landing gear strap. One end holds the assembly and the other hole is attached to an engine lug. If you need a 90 deg angle on the attachment, you can use a control horn.
http://www3.towerhobbies.com/cgi-bin...I=LXDMG5&P=ML#
So far I have had excellent success with this method.
Great idea, I seem to lose them after they break off the cover plate, even though I attach them to the firewall, either in a mid-air or after one (slamming into the ground) and at $24 for the valve and cover plate it gets expensive. Out of the ten 25 FX's that I fly most valve assemblies have broke off the cover plate, which seems very normal in combat. I take it that you put the fuel supply line up and over the threaded portion and that keeps it there? I like you're mounting system too. We still fly 2610 and of course Open-B. I was just getting set to order a couple complete valve assemblies....now I'm going the way you described ...thanks............combat season has begun........[sm=shades_smile.gif]
