RE: Bolt on wing conversion
<div>Do I need to modify the LE. of the wing, reinforce it, or do I just drill and glue in the dowels (two, one on each side of the wing, as opposed to just one in the center). I am pretty clear on the rear bolts and how to do that, my only concern is the LE. of the wing. It is a hassle to line up the wing every time and to trim it out, but the advantage of the wing breaking loose when I ditch her in the brush is also a good thing. So I will sleep on it and decide to either do it or leave it as is.</div><div></div><div>Thanks</div><div></div><div>TB</div>
