RE: Bolt on wing conversion
I had the trimming issue on my trainer until I learned how to install the wing properly. If you will draw some lines with a permanent marker on the bottom of the wing and double check to make sure it's on straight every time you will have very little deviation from flight to flight. Take the time before each flight to make sure everything is right and you won't have trim problems in the air.
