RCU Forums - View Single Post - Bolt on wing conversion
Old 05-05-2010 | 08:49 AM
Bax
Default RE: Bolt on wing conversion
I've had models with rubber-banded wings. Never had to re-trim each time. You just need to install the wing properly each time. If you build the wing saddle correctly, you'll have no problems. With an ARF, you should either make reference lines, or add small pieces of balsa to key the wing in the correct position.
