RCU Forums - View Single Post - Need correct part number for thrust washer
Old 07-18-2003 | 11:25 PM
PatternFlyer
My Feedback: (182)
Default Need correct part number for thrust washer
Hi, BAX,
I need a part number for a thrust washer.
I am using a 91SX-H. It has 9.5mm shaft OD right in front of the front bearing.
I am looking for the thrust washer that has exactly 9.5mm ID and notch for woodruff key.
The part number in the manual of 91SX-H (46120000) is loose fit. It has 10 mm ID when I check at Tower Hobbies.
Would you be able to tell me the part number for 9.5 mm ID?
