Need correct part number for thrust washer
My Feedback: (182)
Hi, BAX,
I need a part number for a thrust washer.
I am using a 91SX-H. It has 9.5mm shaft OD right in front of the front bearing.
I am looking for the thrust washer that has exactly 9.5mm ID and notch for woodruff key.
The part number in the manual of 91SX-H (46120000) is loose fit. It has 10 mm ID when I check at Tower Hobbies.
Would you be able to tell me the part number for 9.5 mm ID?
My Feedback: (182)
Bax,
Thank you for the reply.
the thing is that the thrust washer that I have with the engine is 9.5mm which I believe is a geniune OS part since it came with the engine.
Do you think it is possible to use more than 2 thrust washer to this engine?
I need to use them as spacer to push out the drive washer because the engine is 3mm shorter than 91FX.
thanks,
thanks,
