RE: gst 7.7 power problems
I've had a Genesis since '05, and I have never had that problem. Until, that is, after I put a check valve in the exhaust pressure line to keep the fuel from leaking out the exhaust when I hang it in my shop. That is when the problem started to happen. I the remopved the check valve, and poof! It started to run fantastic again. Go figure...
