RCU Forums - View Single Post - Ignition loads current verses input voltage
Old 05-06-2010 | 10:38 AM
kurt2022
My Feedback: (18)
Default RE: Ignition loads current verses input voltage
norton, That also means the output will increase also, in a motor that means higher rpm and in an ignition coil that means a hotter spark, if you take the regulator or heat sink out of the equation.
