RCU Forums - View Single Post - Ignition loads current verses input voltage
Old 05-06-2010 | 11:03 AM
JNorton's Avatar
JNorton
Default RE: Ignition loads current verses input voltage
ORIGINAL: kurt2022
norton, That also means the output will increase also, in a motor that means higher rpm and in an ignition coil that means a hotter spark, if you take the regulator or heat sink out of the equation.
I want you to think about the original statement - Quote “Check out ohms law!!! The higher the voltage the lower the current draw, FACT!!! “
if this held true you would have less power and the motor would run slower with higher voltage applied.
John
