RCU Forums - View Single Post - Ignition loads current verses input voltage
Old 05-06-2010 | 11:10 AM
jedijody's Avatar
jedijody
Default RE: Ignition loads current verses input voltage
The coil will only discharge enough power to hit ground, the higher the resistance the more power used up to its full capacity. Higher input voltage will provide a higher available secondary voltage but it will not be used if the resistance is low, excess is disipated as heat and not good for the ignition over time.
