RCU Forums - View Single Post - Ignition loads current verses input voltage
Old 05-07-2010 | 06:56 AM
  #62
JNorton's Avatar
JNorton
Default RE: Ignition loads current verses input voltage
ORIGINAL: terryscustom
I would like to ask an application question debating two scenario's. With the 4.8 pack listed below I usually get 3-4 flights before my loaded voltmeter reads 4.9-5.0. Looking for more without re-charging and was considering application #2 below......now I am not sure.
Application one: DLE 55 ignition hooked up to optical kill, heavy duty switch and JR sport 2300mah 4.8v pack with 18-20 mohms impedance.
-VS-
Application two: DLE 55 ignition hooed to optical kill, smartfly 5.2v regulator with heat sink, HD switch, and Hangtimes 6.0 pack with 6.5 mohms impedance.
I am considering moving to A123's down the road is another reason I was going to set the plane up as #2 above. Not interested in needlessly over-powering the ignition.
Thanks!!!
TKG,
I should have asked if you feel using very low internal impedance batteries are worth the additional costs for ignition sources. Or can garden varity packs be used relaibly if they are in good shape.
John
