ORIGINAL: Carsten Groen
Ron,
I explained myself in a wrong way. It's not the canopy FRAME that moves, but the glass that is sucked in.
I also added two more tabs to the frame, and made a fillet of epoxy/fibers in the front and rear of the canoopy to make the frame a little stiffer.
But again, it's the glass that flexes in and out depending on the throttle setting, the frame is ok
Hallo Carsten,
Ok, i understand.
But i was thinking when you didn't do anything on the frame, that it could has an effect on the whole canopy.
Next time when i am going to fly the Viper i will also take al look to the canopy with gear in and full power
Again, good luck with finding the sollution.
Regards Ron
