here is the second part, 1/4 tank i adjusted the idle and needed to adjust the high speed and richen the low. the brass needle on the low speed should be sticking out about 1/16 of an inch it needs to be rich so it can idle with a low idle setting.
i ran it to the end of the tank till it it ran out of fuel .
http://s120.photobucket.com/albums/o...t=MOV00368.flv
