RE: is there a difference between irons?
What you will find the trim iron useful for is sealing down loose pieces of covering or trim in tight spots, once you have completed your plane and started using it. Or, if you need to make a repair or patch which gets in between the control surfaces. I bought one at a swap meet, but didn't think I would use it much. I was suprised how much I did use it.
