RE: T7C Switch Assignments
Krysta,
I have a brand new 7C, 2.4GHz that I purchased to take advantage of the additional receiver at $10.00. I have been reading/programming and then more reading/programming and have found a lot of useful information in this forum. But I continue to not be able to set up the Flaperon function to operate both ailerons. I followed the instructions on page 42 of the manual, and, if I set up the Flap-Trim I can in fact get both ailerons to operate as flaps as I turn the VR dial. That's the good news.
The bad news is that I've gone through the procedure described above (setting up the PMix1 and PMix2) and nothing works. Only the left aileron responds. The right aileron doesn't.
Thinking I may have set some other setting that may be interfering with setting this up so I have gone to additional models (3, 4, 5, etc.) that were not touched, all with the same results. Only the left aileron functions when I try to use the 3-position switch.
Please steer me in the right direction.
