RE: T7C Switch Assignments
Krysta,
To expand just a bit on my above post, I can get both ailerons to work as flaps (both left and right operating together) with the Air Brake function as well as with the VR Dial. The Air Brake function works like a charm with the G switch. What I still can't do (the Air Brake function gives you one flap movement only, with both the up and center G switch positions being OFF, and the down G switch position being ON) is get a two step flap function with the 3-position G switch using the procedure outlined by you above to Guy.<br type="_moz"/>
