ORIGINAL: The1User
Hello Guys,
I am getting ready to start my build and wanted to know what long servo arms you guys use for the HS-85MG ?
Joe
http://www.dubro.com/hobby/ecatalog/dubro/00051.htm
Part #672
The long ones.
The 4 hole arm.
Rod in end-most hole, clevis on elevon should sit about 1.25 to 1.5 inches above elevon. You will have MAX resolution and deflection, coupled with max servo strength, all packaged together with minimun deflection from any slop (you shouldnt have any, but sometimes the metal gears have a little too much backlash).
