RCU Forums - View Single Post - RC 'Robot' Modular Base construction
Old 05-12-2010 | 12:42 PM
dknovick's Avatar
dknovick
Default RE: RC 'Robot' Modular Base construction
ORIGINAL: VolgClawtooth
Repostying here instead of controllers as I encountered an post which makes me think this is the better forum to ask in.
I run a small 'robot' competition at various Sci-Fi Conventions
Cool!
Would this TX/RX combo even work?
As far as I can see, it should be fine.
Will the receiver run off the same batteries as the motors?
technically, yes. You will need a Battery Eliminator Circuit (BEC) to drop the voltage down to 5-6V. This can be a separate piece, or built into the ESC
Do I need one ESC per motor output?
typically, an ESC can only control one motor, so if you want to be able to control two motors independently, you will need two ESCs
You might be able to find a dual h-bridge that you can run from a RX output.
Do I need separate battery packs for each ESC?
You shouldn't as long as your battery can supply enough power for everything (ESCs, receiver, etc.)
and it looks like 8-AA for the TX
-Dave
