RCU Forums - View Single Post - OS 7D carb
Thread: OS 7D carb
Old 05-12-2010 | 01:47 PM
  #37
Roguedog's Avatar
Roguedog
Default RE: OS 7D carb
Jollypopper;
Three solutions for you.
First, you can buy a piece of brass tubing slightly larger than the barrel of the carb rotor drill a hole for the venturi cut a slot verticlly along the length of the tube than cut off the portion with the hole. Next for a press fit widen the slot until it fits into the carb rotor.
Second goto to Tower Hobbies and buy the carb insert for the 9B carbhttp://www3.towerhobbies.com/cgi-bin...amp;I=OSMG3627You will have to modifiy this one as well to get it to fitin the barrel of the carb rotor.
You can buy a perry pump which would work without the carb inserts. Since you're determined to get it running, invest in tuned pipe and header for it as well.
Bryan</p>
