RE: Been quiet on the ole conversion board..
if it is one of the Mac engines the carb is rubber mounted (if I'm remembering right) so the angle would be as simple as a formed hose, but the main problem with the carbs mounted there is the metering diaphram balance hole on the carb being in air flow, it needs a smooth/consistant source
