RCU Forums - View Single Post - Comanche to dauphin fuselage???
Old 05-13-2010 | 04:44 PM
Gothic
Default RE: Comanche to dauphin fuselage???
ORIGINAL: ReadyToGo
hi,
I think it's a great idea because Comanche fuselage still looks a real helicopter and differently from Dauphin, it can be easily removed for one to check the insides.
I think you will have to shorten the servo horns to fit inside the Comanche fuselage.
jc
Hi JC,
The horns I use have 4 hole on all my helis with all the canopies. If you find the canopy is too snug to use with the longer horns just trim the canopy around the horn so it doesn't rub. No need to give up performance of using the longer horns.
G.
