Comanche to dauphin fuselage???
Hello guys,i have a dauphin and i'm pretty much bored with it's appearance.Since the lama,dauphin and comanche are the same,can i fit the fuselage from the comanche on the dauphin?Even with some mods?I'm good on mods
MD
ORIGINAL: Giorgos_cupra
Hello Giorgos
Yes you can change the fuselages but you may also need to change the battery holder. If you notice the Lama 4 has skids and the Co and the Dauphin has wheels.
I have five L4's . One I use the Commanche canopy with the Lama 4 rear with skids
G.
hi,
I think it's a great idea because Comanche fuselage still looks a real helicopter and differently from Dauphin, it can be easily removed for one to check the insides.
I think you will have to shorten the servo horns to fit inside the Comanche fuselage.
jc
jc
MD
ORIGINAL: ReadyToGo
hi,
jc
hi,
jc
Hi JC,
The horns I use have 4 hole on all my helis with all the canopies. If you find the canopy is too snug to use with the longer horns just trim the canopy around the horn so it doesn't rub. No need to give up performance of using the longer horns.
G.
