RCU Forums - View Single Post - Kleen Flo starting fluid as ether
Old 05-16-2010 | 12:01 AM
Diesel Die-hard
Default Kleen Flo starting fluid as ether
<div style="text-align: justify">I'm new to this list and recognise that this may be old ground. If so, my apologies! But does anyone out there know how much ether is actually in Kleen Flo starting fluid? The MSDSsays that it's between 40 and 70 %, which covers a lot of ground!I know that John Deere fluid is the way to go at 80%, but can't seem to find it here in Canada - my local JD dealer sells the Kleen Flo brand instead. Is JDfluid available in Canada??
As far as the Kleen Flo starting fluid goes, it does seem to have a pretty high ether content. The best testing device by far for starting fluids iof unknown ether content is the old Drone fixed compression diesel, which is designed to run on a straight ether/mineral oil mix and will not run alt all well (or at all in some cases!) unless the ether content is right up there. Adding anything other than oil and ether really messes with the Drone. I just tested a brew of 75% Kleen Flo and 25% SAE 30 motor oil (the maker's recommended proportions) in my old faithful "flyer" second model Drone, and it started and ran perfectly, behaving exactly as if the base fuel were all ether. So the ether concentration must be prettyhigh. I tried a fuel made with Gunk Liquid Fire (60% ether) in the same engine, and it didn't work nearly as well, although it did run.
But Liquid Fire isn't all bad news! I also brewed up a half litre of regular diesel fuel using a can of Liquid Fire (about 250 ml), 110 ml of kerosene (treating the heptane content of the Gunk as kerosene equivalent), 125 ml. of castor oil and 15 ml of Amsoil cetane boost additive. In the same engine on the same props, this fuel ran as fast as my last carefully-stored comparison sample of the old Red Max blend, with just a hair more compression and a very slightly richer mixture. Cost of the half litre - about $6.75.
If Icould find out what the real ether content of Kleen Flo is, I'd try a batch using that fluid - it sure did a nice job running the Drone! But I need to know the amount of hydrocarbon to be allowed for when making up the blend.Better yet, I need to find a source of JDfluid!!
Finally, thanks to all those kind folks who put me onto Amsoil cetane boost additive as an ignition improver! Seems to work just great!
</div>
