RCU Forums - View Single Post - Flat spin, finally. Entry question, technical
Old 07-20-2003 | 10:56 AM
Spanky1
Default Flat spin, finally. Entry question, technical
Thank you for the input.
So far phillybaby's technique is what I've tried. But very inconsistent. (for me anyway) Philly baby how much throttle are you using when you pull vert? Are you vert and the off throttle just enough to stop flying? (almost a torque roll)
When moving the aileron back, it seems to pop itself out if you go to far. Is the goal to get the aileron ALL THE WAY opposite the rudder? And if I understand BotleRocketWar, the control surface responsible for the "climb" is the elevator while in the spin.
Thanks again for the input.
Spanky
