RE: Upgrade or replace?
Even with the slider centered, is the tail push rod at 90? You might have a slight off centered slider to get the push rod link at 90. That should solve the problem. I know on my 450 with the slider centered it had a good drift. Once I set the push rod link to 90 everything was locked in.
