RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 05-17-2010 | 06:59 AM
  #6034
craigteffe's Avatar
craigteffe
My Feedback: (24)
Default RE: DL-50 engine
ORIGINAL: squeaky penguin
Hey guys, I'm really puzzled on this one,
I just took my DL out from the first time since winter. I struggled to get it to run solid in the below freezing weather. Now that its warm, I can't get it to stay running. It starts as usual: several flips with choke and a fire, turn off choke and it starts. I give about 1/4 throttle to warm up, and it runs for about 10-30 seconds and just kills, no stuttering or hesitation, it just quits. If I play with choke, I can get it to do this untill my arms feels like it is about to fall off.
Any suggestions?
Sounds like the engine is either running out of fuel or you need to check the ignition battery they will not run worth a crap above 1/4 to 1/2 throttle with a low ignition battery. Change an or charge and cycle the battery and try again.
