ORIGINAL: Diesel Die-hard
<div style="text-align: justify">
Still waiting for one of our Canadian colleagues to tellme if JD starting fluid is available in Canada! Meanwhile, I'll use Kleen-flo for Drone fixed compression fuel. I just tried a first model Drone (plain bearing) on the same stuff withequally good results. </div>
Hi Diesel Die-hard,
Where in BC do you live? Here in Abbotsford our local JD dealer does indeed carry the JDbrand 80% ether starting fluid. Quite a coincidence thatI hopped on here to read up on home brew diesel and saw your post! i picked up a 7oz. can of the stuff just today ($4.65) asI need to try mixing up some fuel for my PAW .15 control line engine. So, yep the JD fluid is available in Canada. Maybe ask your local dealer if they can bring it in for you.
Cheers
Geoff
