RCU Forums - View Single Post - Upgrade or replace?
Old 05-17-2010 | 05:09 PM
Commander_Bob's Avatar
Commander_Bob
Default RE: Upgrade or replace?
I attached some pictures of my setup. Doesn't the push rod have to be 90 because the tail push rod angle is not adjustable. It's just one molded piece.
EDIT: One other thing. With your gyro where do you have the travel limit set and where does the push rod connect to your servo? It seems like I should move it out one hole but then it binds and the travel limiter won't go that low.
ID:	1438039   Click image for larger version
