RCU Forums - View Single Post - Dragon question
Old 05-18-2010 | 01:18 PM
  #111
as722
Default RE: Dragon question
ORIGINAL: Osnabruecker
Hello!
Still waiting for the maiden []
Another question: I am not satisfied with the mounting of the landing flaps. There´s quite a lot of slackness in the 0° and 90° position. I can´t even reach the 90°. Its nearly 80°
Can someone post detail photos of the way you solved this issue?
Thank you!!
Regards
Dirk
I have no problem getting the 90 degrees but I don't use that much as it is not needed, I'm using about 70 degrees. I did notice the "play" when the flaps are up and the only way to fix it is to "overdrive" the servo a little. I'll take some picture of mine later.
Albert
