RE: In flight adjustment using VR knobs
Basically, you want a way to change the percentage of mix "on the fly". Unfortunately, the 10C doesn't have that provision in the mixers. What you want to do is use a point mix and then define the points of mix you need...it will take several flights and a bit of "try and see" to get the mix ratios correct.
